While I'm in there?
While I'm in there?
I'm getting prepped to do my belts and also pulled off the intake manifold to do the ground wires and check the work the PO did, and do a general clean and check.... any other stuff I should do (maintenance wise) while I've got her opened up?
Currently the car has:
LR MAF
Sport Turbo
55lbs inj.
3" exhaust
dp wastegate
The AFR at idle takes a while to stabilize at 14.7 and I changed the O2 sensor but that didn't help...any sensors under the intake that might be to blame?
what about the intake gaskets...just replace them? It looks like one might have been a tiny bit leaky...that vacuum leak could be causing the idle AFR issue, huh?
Sorry for all the questions, I did a ton of searching, but couldn't find all my answers...Thanks guys...(and girls, if you're helping out, too..;-)
Stephen
LR MAF
Sport Turbo
55lbs inj.
3" exhaust
dp wastegate
Stephen
intake manifold gaskets need to be replaced every time the mani is removed. They are a one-time use thing. If you pull off the intake manifold, you should replace all the vacuum lines and do the venturi delete.
Crap, this list is gonna get long, huh? Oh well...thanks for the info, I'm checking into everything being mentioned. Here's a pic of my current condition....
Not 100% true. They are not a crush type like the exhaust gaskets or a head gasket. While it is advisable that they be replaced after an intake removal, in a jam, if they are still intact and not brittle, they can be re-used.
That's the hard part! They've always cracked in half on all the intake's I've pulled. I guess if you put on new ones not long before (couple months maybe?) and had to remove the intake again then they probably wouldn't break.
Very true. I re-used mine, but they were maybe 4000 miles old when I pulled the intake for the 2nd time. The ones that were there when I bought it pretty much crumpled...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yes, the intake gaskets can be reused if they are in good shape – the original factory installed ones will have all aged out by now!
Now for one of my pet peeves – whats with all this colorful silicon vacuum lines? There is no better vacuum line than the stock type hard lines. The connectors, Tees and Ys may need replacement but the hard lines are way better than any flexible ‘vacuum’ line.
If you ask nicely most NAPA stores either has it in stock or will order it for you.
I didn't know NAPA had it tho...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The problem I see with the silicone hose is that it gets softer with heat and its much easier to kink or slip off. The hard plastic lines do not swell or fold over.
Some of the ‘typical’ silicone lines get soft enough that they will come off at boost when they are hot.
And while you like color….I only like it if it is a nice match with other things in the engine bay (like a color that matched AN fittings) – but that’s just personal taste .
On my old NA most of those "superior" vacuum lines were melted i also snapped the line going to the FPR just by slightly pulling it . Even if the silicone lines get soft they wont jump off if they are used together with hose clamps. The silicone lines can even be crimped to check for leaks and change in the idle for example.
