What happened to the delrin steering rack thread?
On the track, it makes the steering more precise, and ensures the steering "returns to center" after high lateral G loading.
It is a modification that one would likely not notice on the street.
No noise, no lubrication - because nothing moves. The delrin mount forms a rigid link between the rack and the subframe (cross member). (The way it's designed, there is no movement - unlike a delrin bushing for a sway bar.)
If you havent replaced the bushing on your car its probably beat to **** and should be replaced with the 10$ OE replacement.
Even the stock replacement should provide a noticeable improvement, correct?
So where can we buy these?
...and how easy / hard / time consuming are they to instal?
Paragon has the one bushing that prevents side to side movement and makes the most difference.
Not hard to install. Unbolt the rack from the crossmember, swap bushings, bolt it back. No alignment etc. I dont know how much space you have to do that with power steering though.
