WTB: Door harnesses or 4-pin speaker connectors
I'm looking for 1987 door harnesses that have the provisions for power door locks and the 10-speaker setup. I need both sides. I had my original ones in the attic, but I can't find them. I had the opportunity to get the harnesses from another car a while ago, but I was counting on using my old harnesses ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I'd be happy with finding just the 4-pin speaker connectors. If anyone has trashed harnesses that wouldn't mind cutting off the connectors, that will work too. They're flat 4-pin connectors found at the bottom of the door where the wiring harness goes back towards the door lock actuators. Mine were taped to the harness and stuffed in the clips - they're behind and below where the door pockets would be. All 1987+ cars should have them.
I was not able to find the connector and pins in PET; I was just going to order new ones.
