Need some parts
Need some parts
Need the following parts...
1 951.110.061.03 metal tube for breather and boost control valve lines
1 951.110.315.01 heat shield between turbo and upper balance shaft cover
1 951.110.154.03 bracket for the above heat shield
1 951.110.597.01 bracket for idle control valve
1 999.512.395.02 clamp for idle control valve
1 Test pipe gasket
TIA!
1 Test pipe gasket
TIA!
