'86 vs '87 Transaxle
Looking at doing a tranny re-seal and re-fresh this spring. Markus Blaszak has an '87 turbo tranny he is rebuilding and has made it avaiable to me for a swap. My car is an '86 951.
My question is: Other than the cooler, are there any other differences between '86 and '87 transaxles? Also, since my car only sees 1 or 2 track days a year and the rest is street use, do you think the loss of the cooler is detrimental?
OK, either there is no diference and you're all saying what a stupid question this was, or nobody knows. I'm sure somebody knows. Any takers?
I would go for the one with the cooler. Ive had good expericence with transmissions with coolers vs. ones without
Thank you for your replies.
I have the original transaxle with cooler in my car, which is an '86. It has a leak at one of the seals and it crunchs slightly on the upshift to 2nd and the downshift to 2nd when cold. Once warm and you take your time, it shifts fine. It also crunched repeatedly downshifting into 2nd when warm at the track last year. Obviously synchros are worn. I don't want to cause more damage so I would like to have it fixed.
While talking to Markus Blaszak about it he said he had an '87 transaxle without cooler ready to go. This is what he had to do to this shelf tranny:
- New synchros for 1-2-3-4, 5th was fine.
- New ring and pinion
- new differential bearings
- New seals and gaskets
- Apparantly Pinion and shaft bearings are OK.
He wants $1260.00 Cnd. for the tranny. Is this a good buy?
Question is:
- Will my existing transaxle need the same amount of work once he gets it apart?
- Should I just opt for the '87 tranny he has ready to go and do a swap?
- Will it effect resale 10 years from now because it is not the original tranny?
- Should I worry about the loss of the cooler for mainly a street car?
Question is:
years ago I had my Turbo S box torn down and rebuild with new syncros for $700.
I was in the middle of clutch job so the tranny was out anyway. Figured I get it done while I was there. No reall issues in just preventative 100k miles wear check.
I would not worry about resale value or not having a cooler on mostly street car.
A new R/P set is about $1000-1200 by itself, and close to another $1000 in labor to setup the backlash, depth, and preload on the diff and pinion. Something doesnt sound right.
Very unusual that the ring and pinion gear were worn out enough that they required replacement, but the pinion and various other bearings were ok?
