hot side is it normal.
Basic Sponsor
I just pulled this turbo and as I cleaned the hot side the blades look chopped is this normal?
tia
lart
tia
lart
Basic Sponsor
it's a LR sport 75
Basic Sponsor
Basic Sponsor
so the question to the turbo gurus's will this turbo work okay with the clipped blades?
jeez people, can't you see? ...... he doesn't care about the blades...duh.. he's just trying to show you that he has a turbo (LR sport 75, to be exact) that he will be selling on his ebay page (la_951parts), because he can't sell it here.... because he does not want to pay the sponsorship fee.
how was that luis?!?! haha your welcome for the bump (plug!)
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Basic Sponsor
Basic Sponsor
yea, i was kind of thinking more along the lines of.... maybe if i plugged his product he might generously send me a turn signal relay that just went out in my car....*wink*wink*nudge*nudge*
shipping to 70506
shipping to 70506
A common trick to increase the output of a turbocharger is "clipping" the turbine wheel. When the turbine wheel (on the "hot side") is clipped, the fins are cut away at a slight angle (usually between 7 and 10 degrees), thereby reducing the amount of metal that is in the path of the exhaust gasses. The reason this is done is to lower the resistance of the turbo to exhaust gasses flowing through it.
At high RPMs, clipping increases engine horsepower, since the turbo is allowing the exhaust gasses to escape more quickly (and at high RPMs, the turbo can only spin so fast). At low RPMs, clipping tends to slightly increase turbo lag, since less fin-area means that the turbocharger will take longer to get up to speed. This tradeoff is typically well worth the upper-range power gains."
Basic Sponsor
loss of 10% down low to pick up 5% up top only make sense in a car that is up top 95% of the time...
