Annoying seat bolt problem
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
I have an S2 with power seats, each held in with six 8mm bolts with a 6mm hex socket head.
One of the hex head bolts has been rounded out. I've got a 1/2" drive 6mm driver, I tried hammering it in a bit to get a bit more bite, but no succcess, and I don't want to damage the head further.
Fortunately, it's in a relatively accessable position: rear-most on outside track near the door.
So: What is recommended method for removal? Some sort of "easy out" bit? Something especially designed for damaged hex socket bolts? Cutting a slot across the head and using a screwdriver?
Ideas and experiences welcome.
Do you have an extractor set? If you do, I recently had the same problem with a brake caliper allen head bolt on my scooter and hammering the most suitable sized left-hand spiral extractor into the opening and twisting it got the bolt to turn.
I've always had good luck pounding in a larger torx or allen bit or pounding a socket over the outside of the head.
Alternatively,
1) grab the outside of the head w/ a vice grip
2) grind 2 opposing flats to put a wrench on it
Alternatively,
The tricky thing about this bolt is the head is below the level of seat track. So can't get anything onto the outside of the head, just the inside.
I've ordered a set of extractors from ebay, so that's one possible solution. The torx head driver also sounds promising, if I can figure out the right size.
Before you try either, put the bolt just forward of this one back in and tighten it down. May relieve some of the tension on it and ease extraction.
