Transaxle fill levels
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
How important is the exact volume of gear oil in the transaxle?
The reason I ask is I've just changed the transaxle oil (used Nulon 75W-90 synthetic to refill), and I ended up putting in about 0.5 litres more than I got out!
I put in exactly 2.6 litres, which was a little over full (dribbling out the fill plug when I removed the fill hose), but I notice Clark says he filled it to the fill hole, instead of 6-8mm below.
I took it around the block, and it feels a bit "heavier" than it did... not quite as free revving perhaps? Could be my imagination -- I'll take it for a longer run tomorrow.
In any case I thought I'd ask if having it slightly overfilled could conceiveably cause any problems -- I can always let a bit out if that is the case.
Also interested to hear what running it with a up to 0.5 litres less than than that might do... FWIW, the tranny sounds fine (no obvious bearing noise or such), and shifting was always easy.
I just put 2 litres in mine as per FWSM specs approx fill volume, and also because Castrol Syntrax synthetic costs $30 per litre bottle.
Did you change the driveshaft seals while you were in there?
I wonder what the difference between the FWSM 2.0 litre capacity and Clark's 2.6 litre capacity is down to? (It makes me feel better that the 2.0 litres I got out was at least FWSM spec.) Could the "6-8mm below the fill hole level" spec possibly account for 0.5 litre? Sounds like a lot...
And no, I didn't do the seals... I haven't got a triple square (but at least I know for sure what tool I need now).
I've always filled it up to the bottom of the fill hole, numerous times on different cars.
Then again, I have exploded 4 transaxles, so... maybe I'm doing it wrong!
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I fill to 1/4 inch (4-6mm) below the fill plug port, and like you, have never had a problem, but then I have only logged about 60K in miles on my cars... maybe I'm doing it all wrong.
[QUOTE=Then again, I have exploded 4 transaxles, so... maybe I'm doing it wrong!
[/QUOTE]
I think your name says it all. Drifta944. That's the reason you keep blowing them up.
There's at least a thousand things you can do wrong on this car. My money says you can't overfill the transaxle, at least to the extent to cause harm....
I filled mine up to the bottom of the check/fill plug hole. My gearbox felt smoother after I changed the fluid. I used redline 75W90 with limited slip additive, not sure what was in there before.
2 of the 4 I exploded were during my autocross days, long before I got into drifting. The 3rd slowly disintegrated over time. And the 4th was indeed during a drift run.
Anyway, back on topic!!
