2pc Crossover Leak
Anyone have problems with a 2pc crossover leaking from the connection. Mine has a copper gasket and vband and when I pressurize the pipe it leaks at the joint. I made sure by submerging it in water.
I was going to just replace the copper gasket but Im concerned that even with that it wont seal propoerly.
Any thoughts?
Brian
Any thoughts?
Brian
I didn't know we were concerned about illegal stuff here. Considering I don't have a cat and I am using a catch can. Better call the police.
But seriously, I have the same problem with my 2 piece LR X-over pipe. I think I need a new V-band clamp because when I tightened it down it wasn't lined up perfectly and the edges of the clamp got pushed out. This time I will get the wastegate and header side bolted in and then jack up the pipe slightly to line up the the 2 pieces and then clamp it on tight. If that doesn't work I'll probably have to get a new X-over pipe all together.
I have fought leaks with mine as well. I've got one of the very early ones, so it is actually a 3 piece ! It's a great concept, but that is the LAST place you want exhaust leaks. I've considered going back to the one piece for that reason.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I do a similar mod for my customers when I install an engine– except I use a three bolt flange with an Oring – just the same as the connection on the header side. It seems to work better…and its up a little higher by the O2 sensor, no problem fitting to the engine / chassis.
I still have a bunch of laser cut flanges in case anybody needs the mod done…
I have a leak at the y pipe I had welded, at the exhaust manifold flanges, and right after the wastegate... I used to have one flange actually loose on the car until I tightened it. I didn't find out I had another leak until the car flooded one time and fuel dripped out of the exhaust mani right where it bolts up to the exhaust ports. I basically need to just purchase an entirely new system from engine to turbo.
I'd love to have a local shop fab up a front mount, equal length, tuned primary length, turbo manifold and get rid of the cross over system all together if it weren't such an involved process.
