vacuum check valve?
Hey Man
Depending on the size you need there's the vac check valve on the brake booster. It's the blue valve in-line w/ the booster. There are larger aftermarket ones depending on your requirements.
Vac Check Valve
Vac Check Valve
I tried that but it didnt work, it's meant to let vac through and no pressure. I dont think it works as efficiently the other way around. I tried blowing through it and it was good but when you apply strong vacuum it still pulls through.
