Lindsey Wiring Harness Questions
Has anyone used these wiring harnesses?
http://www.lindseyracing.com/LR/Parts/HARNESS.html
I tried calling Lindsey (its Saturday so probably not open) for more details.
Anyways, I have the "crispy harness syndrome" and want to replace before the engine goes in the car.
If I get the fuel injector harness, crank position harness, idle stabilizer and misc harness does that basically replace everything?
Is this a good way to go to get a new wiring harness? Anyone have anuy experience. I will try Lindsey again today but probably cant get ahold of them until monday. I need to make a nice order so I am think of just adding this to the order.
-Dana
-Dana
You won't be disappointed. I did just the fuel injector harness on a previous 951, and on my current 951 I replaced everything with all the harnesses Lindsey had to offer at the time and have not had any issues at all electrically under the hood. They are top notch pieces.
I have all three harnesses. Easy to install and eliminates the old dried up stiff lines. If you can find yourself some 3M-CC4 cable cleaner...which is expensive... I highly recommend that for cleaning up any oil, dirt, and glue on the old harness.
I'm also using the LR harness. You'll want a good tool to extract the pins from the DME though, try EagleDay.
My Injector harness covering (Red) has faded a bit but I am still without a hood so maybe the sun here has done that over the years it's been standing.
