Anyone Ever Burned Multiple Exhaust Valves?? - Carnage Photos Inside
Try testing the injectors and the injector wiring. Perhaps two got clogged or started failing and werent injecting properly, or the wiring was failing resulting in low voltage to two injectors, which would make them open a bit but not fully, leading to a lean cylinder. I have had stock injector fail fully open.
