Largest Injector
Rocket Scientist
What's the largest injector (one per cylinder) you've run or seen run on a 951? As more move into the E85 world...I'm just curious how large people have gone specifically on a 951. I'm well aware of the DSM/Honda world. Thanks.
Rocket Scientist
Yeah, I'm familiar with the usual 70, 80 and 90#. I'm wondering about larger then those. I think most aren't, no need to unless you're running E85 or making very serious power.
Let me guess what this is about....
I ran 120lb/hr (http://www.racetronix.biz/itemdesc.a...1D134x&eq=&Tp=) ones for a very short bit, didnt run very well though since I didnt have a cam sensor wired up for sequential ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
I will eventually be running either those 120lb/hr ones, or far more likely I will switch to Injector Dynamics 1000 (1000CCs/100lbhr) injectors.
Corleone runs 1680cc inj on his 3L.
Yep, an older Link setup. He was actually running the inj at 100% duty cycle if you can believe that. Well that's what he said, but I think it was that the pump he had was running out of puff. That was a few years ago now.
As a side note, he seemed pretty hell bent on improving the cooling from the stock setup. Not sure how far he got on this. He doesn't drive his car a whole lot from memory.
^^ There you go ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Hey Duke, how is it for cold start / idle etc??
