Front main seal - why does it still leak?
I replaced the drive gear which hae the groove our cars eventually get and figured that would take care of it. I also replaced the seal that gets pressed into the pump and the seal on the crankshaft that fits into the end of the drive gear.
So why does it still leak?
I think the seal that's pressed into the pump ended up very slightly crooked. Is that enough for it to leak? I scratched the camshaft during all this. I polished the scratch as best I could and it is under the drive gear so that shouldnt be a problem right?
I torqued it all down properly and get oil pressure.
So new drive gear, front seal, and green o-ring in front of the gear? Did you put the big flat washer on? It goes on top of the green o-ring, to sandwich the o-ring between the washer and drive gear.
How did you install the front seal? I have found its best to use a section of PVC pipe which matches the seal, then put a small block of wood on the end of the pipe and tap the center of the wood with a hammer. That helps it go in straight.
Its also possible that the spring thats inside the lip of the seal rolled off, and thus thats not sealing.
Yes new o-ring and the washer was installed. I can't imagine it going together with the washer in the wrong place.
I installed the seal by using the pulley gear turned around and placing the old drive gear over that and then tightening down the crankshaft bolt.
Well if it can be done, I bet that's what I managed to do ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
At least now I know the oil pump does not need to come off. That will save me TONS of work that I created when I stripped 2 of the bolt holes and broke one bolt because I had the torque setting way too high. I got a new skill for the trouble though, tap and insert new threads.
Probably just best to order new seal and o-ring.
Lube the seal thoroughly before you install it. I use assembly lube on and also on the drive gear. I have had trouble with the front seal too. The home made installer and assembly lube solved it for me.
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
If the seal is seated even slightly crookedly, it's probably distorted and not going to seal properly.
On some cars these seem to be a tighter fit than on others. I wasted two seals before I got the third one to seat properly when I did mine. It was getting tedious and expensive.
Other people have reported they can push theirs in with their fingers. Not mine...
Actually, he didn't mention if he had used a tube of similar diameter to the the seal to actually press on the seal; pressing with the gear itself is not very reliable.
I used a short section of steel pipe that was about 1mm less in outer diameter than the seal. Other materials, such as PVC or even hard wood could also be used.
Actually, he didn't mention if he had used a tube of similar diameter to the the seal to actuall press on the seal; pressing with the gear itself is not very reliable.
You want a section of tube that has an outer diameter as close as possible but not greater than, the outer diameter of the seal. Stouter (thicker pipe) material is better than thinner. Make sure you cut as square as possible. About 1" in length should work IIRC.
