Problem with internal air blower / fan
Merry Christmas all.
All of a sudden, the fan in my '86 951 won't switch on, which is an issue as its very hot this time of the year in Australia, and I can't use the a/c without it.
To try and fix it, so far I have done the following:
1. Checked its fuse (while in position with fuse tester). Seems fine.
2. Pulled out relevant relay and removed cap / housing. I am not very knowledgeable about relays, so could not readily assess if there was an issue. I have put it back in (I don't know how to bypass it).
All of the other controls work for the heating / air con, except the fan and the front demister which relies on the fan.
Any thoughts / ideas appreciated please (other than buying a new fan motor and/or relay).
Ebs
Ebs
possibly the resistor located in the top of the blower housing right where the plug goes in.
here's the part inquiry from Sunset.
165.89 and in stock, plus 9-12 dollars shipping. Thanks, Jeff. On quote 65500.
If you have purchased from us before you are probably in our system. If you are a new customer here is how to order:
To order you can phone in, numbers are below. Or to
place an order with our secure online order form use
https://www.sunsetimports.net/phone.php?make=Porsche
If you have a fresh quote number from me that isn't older than about 3 weeks please include that in the comments box. Include any changes you'd like to make to that quote if needed.
Porsche Parts On Sale: 944 Turbo supplement 12.00, Winter tire and wheel sets with the Cayenne 18" Turbo wheel for 1200 dollars. Other Cayenne and 997 wheels, and possible packages are available soon but at higher prices.
Sunset Porsche phone 1-800-346-0182
attn: Jeff Clark fax 1-503-601-3090
4030 SW 139th way
Beaverton OR 97005
Parts department hours: Pacific Time
Mon-Fri 8-6 Saturday 10-2 (4 hours)
Closed Sunday
Sunset Imports website:
www.sunsetimports.com
Due to increasing emails, please phone in the order if parts need to be ordered overnight.
Sent: Monday, October 26, 2009 6:51 PM
To: Jeff Clark
Subject: part inquiry
Jeff,
Please check price and availability.
fan resistor
944.616.101.00
Greg
4030 SW 139th way
Beaverton OR 97005
Closed Sunday
To: Jeff Clark
Jeff,
fan resistor
944.616.101.00
Greg
Thanks.
The whole unit went off, then came back on and worked perfectly (briefly) until I tried to turn it up and then died again completely.
Be interesting to substitute the relay initially.
