Venturi Bypass
Here ye are.. https://rennlist.com/forums/944-turb...te-thread.html
you're both welcome
As for a dash, I'd say try ebay or your local craigslist auctions.
What color are you looking for?
I did a quick search and found a couple for sale. If you are not on PelicanParts I can contact these guys for an email or phone number for you if you need it. Send me a PM if so.
black:
http://forums.pelicanparts.com/porsc...-pa-150-a.html
here is a black leather one:
http://forums.pelicanparts.com/porsc...o-dash-fs.html
beige:
http://forums.pelicanparts.com/porsc...9-turbo-s.html
black:
beige:
I did that - fixed a pretty decent vacuum leak in the process...getting rid of that birds nest removed about 8 clamped connection points that are potential leaks...
I also pulled the cycling valve and the metal pipes out while I was under there as well. Cleans stuff up big time...
Im looking for a black one. Ill check those links out. Thanks a lot. I have a mint 87 n/a and 87S with perfect dashes its so tempting to switch one of them.
