ABS conversion??
#61
True Olli, but when you read above where the factory was aware of the situation and posted bulletins to the Rothmans teams, why was it left to a switch?
Do you see anything wrong with an Auto Reset?
#62
Nothing wrong with an auto reset. After all it was a Bosch unit, and of course it was matter of money. ABS systems were used only few years and new versions were under developement. It was just quick and dirty solution to install a switch. In most case ABS installed to "only street" 951's ABS worked just fine.
