new release SPEC Aluminum Pressure Plate
Basic Sponsor
SPEC has been working on this for some time but it was finally introduced
at the SEMA show this year.
The new Aluminum Pressure Plate for the 951. It's lighter then
anything else and rebuildable.
![](http://www.lindseyracing.com/pics/SPECALUMPP.jpg)
You can read a little about it on our SPEC clutch page if your interested in
finding out more and we now stock it and make it available as an option
with any of their 951 clutch kits.
http://www.lindseyracing.com/LR/Part...CHSPEC951.html
Mike or Dave Lindsey
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Hey Mike how does that differ from the other Light weight Spec Aluminum Pressure Plate I purchased from you a few years ago?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Small Business Partner
i think the difference is the older one had just an aluminum outer looks like that one has and aluminum backing on the (steel ) friction surface .. I think the aluminum would dissipate the heat better than an all steel one wich could help performance ..
Basic Sponsor
"Hey Mike how does that differ from the other Light weight Spec Aluminum Pressure Plate I purchased from you a few years ago?"
The cover is aluminum versus steel on the other model. Same clamp force. 3.6 pounds lighter.
Basic Sponsor
"i think the difference is the older one had just an aluminum outer looks like that one has and aluminum backing on the (steel ) friction surface .. I think the aluminum would dissipate the heat better than an all steel one wich could help performance .. "
Actually, the previous had a steel cover and aluminum friction ring with steel bolt on wear surface. This has aluminum cover, aluminum friction ring with steel wear surface. We offer both now.
Basic Sponsor
"Ah, you are right - guess I didn't take a good look at it in the first place "
They are doing the same thing as is done on the aluminum flywheels. A steel
replacable friction surface. This makes the PP rebuildable for those who tear
up clutches or wear them out more then the average guy.
Why does the Spec product seem to polarise people's opinions?
