350whp on 92 octane - How do I get there?
#91
#92
Alright so basically if I'm running 16 psi I should hope to see 32 psi or less on the exhaust side, correct?
And less on the exhaust side would be that much better I'm guessing. With a target of near 16 psi on both sides (intake and exhaust)
#93
Small Business Partner
#95
I remember being told that turbo cars needed some exhaust restriction to help with spoolup. The theory being that if you had too big of an exhaust it would increase lag. I wonder how the 3.5"-5" SFR unit will eventually go?
#96
They mean restriction before the turbo Patrick. If you have too large a crossover there wont be as much of velocity there hurting your spoolup but too small and you have a restriction. Post turbo you want as little as possible
#98
Correct, Special tool before he turned into a thief confirmed the same thing.
#99
Exactly, less restriction after the turbo will help spool up.
#100
Drive-by provocation guy
What is the best way to tap in to get backpressure readings?
#101
Yep as we ahve all seen real world proof of this as the cat delete is such a major before and after difference because it is a major point of backpressure.
I think most see 500rpm or more in better spool up and more over all boost made as well just from the cat delete alone.
My mech has about 20 years of racing exp under his belt mostly with prepping other's cars and he worked with Alex Job, etc. and he always said if you want some major gains with the 951 do some work on the exhaust side of the head.
#102
#103
#104
Do you run the pressure gauge into the car? It seems it needs a bit of copper tubing to get the gas cool before it would go into a gauge? Maybe you are you are using a pressure transducer type gauge?
-Dana
-Dana
