Watsegate Technical information
I am looking for some technical information on the 944 turbo wastegate. I am not sure what to look for but everything is welcome
If there's a difference in the 220 and 250 hp version let me know.
It's for a study about the 944 Turbo
Etienne
Etienne
Its made by KKK I think its 44mm it has the pressure on the back of it . it has a hex cut in the face so you can lap the seat using an hex key and power drill it has a cracking pressure of about 7psi or up to about 11psi with 8mm of shims i think it genrally struggles with creep and control beyond about 17psi is the genral belief on this forum .
I think the most cost effective upgrade is the lindsey actulator upgrade for the standard wastegate .
Like Thom says, the fins are the only difference. 100% interchangable. I disagree on
the years though.
the years though.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Well perhaps the units with large fins found their way on a handful of some '87+ non-S cars, but I'm pretty confident all 250 models had the units with smaller fins.
