Should these scare me?
That Guy
http://cgi.ebay.com/ebaymotors/ws/eB...d=290331735298
good deal but ebay for the most part scares me..
thoughts?
-Ian
thoughts?
-Ian
Hey Man
Be aware that you may need OE radius base lugnuts and the studs may be too long for the OE aluminum closed cap type. They may require the open lug style. The lugnuts in the photo look beveled to me.
I'm running these exact spacers on my 911 (1" in front and 1.5" in back) and they have been problem free since I put them on a couple years ago. I'm 80% sure I bought them from this exact seller... As mentioned, the base lug nuts are standard taper, not the Porsche radius style but that is ok as the lugnuts come with the spacers. I'm using the standard Porsche closed end lug nuts on the studs themselves and they are working ok with the Mille Miglia Turbo Twist replica wheels I have installed.
The price is very good...
I bought some spacers from them.. the hubcentric center hole did not fit. I milled it out. But it was an adapter from 5x130 to 5x4.5 Is the center hub a different size between an '86 and all years after?
That Guy
hah wow. so I just went out to measure the hubcentric hole only on the BBS's I bought a year ago.. only to realize that one of them has a 1.5" crack in the lip! grrrr
Guess I will just stick with the phone dials hahah
The front hubs on the 86 don't like spacers, you have to take off material and in my case, I thought it was way too much material. One more reason to go to 87+ hubs, they don't need machining to fit.
One thing - having spacers on the front is a bit of a pain any time you want to do any work to the front that requires access without the spacers (changing the rotors, bearings, regreasing the bearings, etc.). At a minimum, you need someone else around to hold the brakes for you while you remove the front spacers.
On the link Ian posted, you can see how much material they took out of the back side. I also think that some 86 hubs have a little more taper on them at the base making the problem even worse. I was trying to use a standard spacer and had to machine the inside out to get it to fit. I didn't run it for long, not much material was left.
I too have spacers on the front of my of '86 with no problems. I bought them from http://www.wheelenhancement.com/index.php
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
first, your car might feel like crap with this garbage added on... if you're asking the question - then you already know the answer, yet Porsche racers prove conventional wisdom wrong all the time and report zero failures/deaths. but the facts remain, your safety resting on five studs that are experiencing addtional loads and resonances that were never intended to be added, all coming on in microsecond bursts if you happen to like to go fast... ask nascar what they think of wheel spacers...
And seriously - "ask nascar"?? If there's anything to it, why don't YOU ask Nascar and get back to us?
