Removing oil pressure sender....
Or, I used a 24mm crowsfoot from amazon (came in a set for $11 shipped) in combo with a 1 ft socket extension, and then a ratchet wrench from where the tire normally is
Used a 24mm wrench to get it out today. Replaced it with this and relocated the sender. No more leaks either....
http://www.ebay.com/itm/180783055438...#ht_1489wt_986
I have it located right below the power steering reservoir. For a couple of reasons. I got a kit from O'reillys that included the 1/4an fittings and a clear plastic hose. I wasn't too fond of a plastic hose but thats all they had. It does only have relatively low pressure but it is close to the header that has me worried. Did some searching for a 1 foot stainless line and came up empty handed. I hear that Auto Meter sells 1 foot lengths. So far no leaks and seems accurate. But who really knows....
Sorry iPhone pics....
OR, if you don't want to cut up one of your precious wrenches... buy a new one!
http://www.sears.com/shc/s/p_10153_1...rd=thin+wrench
Every one should own a set of pump wrenches!
This car was made for those "pump wrenches"
I wish Harbor Freight carried those
Pump wrenches are one of those things that, once you get them, you can't believe you ever lived without them. I use mine all the time.
My OPS wrench is the open end of a 15/16 wrench cut off, then I welded two 5/8 nuts to the "stub". Instant crows foot.
I never saw those before !! I searched under pump wrench....
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Thanks bud !!
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Best regards
Ed
