Cam housing torque
Clarks garage is your friend. They have all of the assembly instructions most people need for home fixes. The Cam Tower is torqed to 14 ft-lbs. You have to remember that you are putting a steel screw into an aluminum block. Over torquing can be a problem.
http://www.clarks-garage.com/
