Camber Plate Needle bearing worn out
Old 10-17-2009, 12:40 AM
beebone
beebone's Avatar
Default Camber Plate Needle bearing worn out
Folks,
Other question, the P.steering system has been re-built, but the squeal came out when turing to right. My mech said the needle bearing of camber plate worn out and the squeal came from.
So, I took the car to other mech he said the squeal may be the noise from PS hydralic.
My questions:
1.) What if I change the camber plate, is there any best choice of camber plate, that I use the M030 Koni strut with Hypercoil 2.5" ID spring, Racing Edage srping hat.
2.) Do you guys think is the squeal related to needle bearing? or the shaft of the Koni strut?
Old 10-17-2009, 10:49 AM
Phil R
Phil R's Avatar
2. I dont think the squeal comes from the strut. noise from the PS system is very common on all types of cars.
Quick Reply: Camber Plate Needle bearing worn out
