Bigger Snorkel Project
4 Attachment(s)
I got board sunday and decided to enlarge my snorkel.
First off my car: I am running a larger turbo SFR stage 1, vitesse MAF stealth, SFR headers and 3" full exhaust with his quiet muffler, 72lb injectors, vitesse boost controler running from the SMT6 piggyback, ported and polished head, and finally JE lighter pistons with 8.2:1 compression ratio. I knew that my snorkel was now the restrictive link in my set up. So I decided to get creative. First I took took my best shape snorkel and cut it down the center underneath. Then I cut my extra snorkel as seen in the first picture Then I used a bunch of balls to enlarge the snorkel to the bigger size. I then cut the piece from the old snorkel to fit the new enlarged crack. Then all it took was a polly welder, which is nothing more than a different tip soldering iron, to melt it back together. In all it enlarged it about 40% more in volume. I still think that it is not quite big enough but it should flow about 40% more air and give me a good top end hp jump. I will dyno it when I get a chance for you guys to see how much of a restrictive point it is. |
Originally Posted by Richgreenster
(Post 6963298)
I got board sunday and decided to enlarge my snorkel...
-So you get those emails too, then! ;) Keef |
Next you need to enlarge the opening between the Air Box and the MAF. Open it up to 3" to improve the flow.
1 Attachment(s)
I all ready did John. I guess I forgot to mention that.
Originally Posted by VWaddict
(Post 6963369)
Huh...
well, I'm a big kid. Read, "a bunch of balls" and, "enlarged crack" then laughed out loud. just sounds like a "dirty" job. ;)
(Post 6963448)
Only restriction left is where the snorkel attaches to the airbox
Originally Posted by jasonlp
(Post 6963631)
looks really good
(Post 6963298)
