DIY Tuning walk-through (TunerPro)
#62
Great xdf file for the turbo. I've been trying to pin down a lot of the things you've got in your xdf. One thing I'm trying to find out is the null time for seimens 55lb injectors. also Ive tried running the fqs scaler at 90 for the 55lb injectors and it would idle up and down and then cut off. the magic number for them seems to be around 107-105 with that setting the afr's are right back to where they were with the stock injectors. Any ideas. ?
#66
Small Business Partner
#67
Rogue, got it all fired up and running good heading out for a test drive with the new V5.. Idle still is around 1200 thats the lowest i could get it.. Ill post back after the test drive... Awesome news on the ALDL.
#70
I would check to make sure your throttle is completely closing, and the TPS is operating correctly.
-Rogue
#72
No problem. Lmk I started to tinker with it and create a deffinition file have basicly everything in the tables added. Just couldn't get tunerpro to connect
#73
#74
Started to work on it...
Stay patient guys - this should be really cool, real-time cell tracing will eliminate much of the guesswork with tuning.
-Rogue
-Rogue
