UPDATED FS: 1986 951 Parting
I have an 1986 951 that I am parting out. II check this site a few times a day so I will respond as quickly as I can. I will also do my best to keep the post updated with the parts list. Pictures can be provided on an as needed basis. Actual shipping & handling cost will be buyers responsibility to pay. In your Paypal payments please indicate what you bought as I am shipping a bunch of stuff out and don’t want to get things mixed up.
New Parts
qty
1 Set of aluminum pedal covers engraved with 944 - $40
1 Rear license plate cover w/ light - $25
1 Set Brake duct scoops (944.341.051.01) - $20
1 K&N 951 stock air filter - $25
2 Head light washer jets (911.628.071.01) - $15
2 Set Stabilizer bracket early model 944’s & 924 & 924S (944.343.735.00 & 944.343.736.00) - $35
1 Early Control Arms ball joint - $15
Performance/Aftermarket
qty
1 Set Autothority chips (DME & KLR – 24 PIN) - $125
Engine
qty
2 Set of 8 lifters - $90
1 Set of 7 lifters - $75
1 Crank shaft (good condition) - $100
1 951 cam housing & cam - $75
2 M44/51 engine block w/ cradle (scoring in cylinder walls) - $50
1 Waterpump w/ no guard - $30
1 951 engine support (oil side) - $50
2 Sets of balance shafts w/ covers - $30
2 Oil pump - $30
1 Balance shaft front cover w/ power steering mount - $15
2 Air oil separator - $20
1 951 Fuel pump - $35
Turbo
qty
1 Set of stock intercooler pipes - $20
1 951 stock intercooler - $75
1 Stock waste gate (works well) - $40
Engine Accessories
qty
1 Starters (tested) - $40
2 Alternator shrouds - $5
1 Power Steering reservoir - $10
1 AC compressor (works) - $50
1 Window Washer reservoir tank - $15
Transmission/Drivetrain/Clutch
qty
1 951 Trans w/ cooler (Non-LSD) - $500
Brakes
qty
1 Brake reservoir tank - $20
New Parts
qty
qty
Engine
qty
2 Oil pump - $30
Turbo
qty
Engine Accessories
qty
qty
Brakes
qty
Got my stuff a couple days ago and put in the boost enhancer. Nice. I like the way the boost responds now. And the seat belts are nice too. Never noticed how bad mine were before. When I was putting in the driver seat belt I noticed the PO took out the 4x6 speakers and replaced them with some cheap 5" oval. More work to do now. Great...
Im looking for a set of early offset 16" Teledials (or do you guys call them phonedials) for my 951.
I guess i need 7" and 8" wheels.
XUPKID2 - any idea on shipping to the UK?
