Window Roll Up Help
Wondering if there is a way to manually roll up a window when the battery is disconnected. Im unable to connect a battery but need to roll the window up. I have access to the motor and it appears to only have 2 wires connected. One blue and one blue w/ a stripe. Any thoughts on how to get the window up? Is there a way to manually do it?
Any help is appreciated.
Brian
Brian
I dont know jack about electricity but if you have something to provide power to it like a battery or something with terminals, I would imagine the motor would go up... The striped cable would be ground? Who knows if the voltage to that is regulated or whatever.
Aside from electicity, you might be able to just move the scissors thing by hand as the motor should spin freely.
Good luck.
Disclaimer: I could be 100% incorrect
Good luck.
