x-over confusion
x-over confusion
I ordered a 2 pc crossover and what I got leaves me fairly confused. I gathered that I needed a small tube piece that actually connects from the x-over to the wastegate, so I found one for a good price.
What I can't understand is how the hell I connect the tube piece to the x-over. There is a flange on the end of the x-over, and on the diagrams I found at dcauto it shows another flange on the x-over itself. Clearly there is no such flange in my pictures.
What am I missing here?
Basic Sponsor
x over
I know I have an 86 and I have the two piece. But im not sure if when they were converting to the two piece they didn't just cut the pipe and slide it together like the way they changed the other end that goes to the cat...
951saga's post shows you what you need. You need:
One of these:
http://www.944online.com/cgi-bin/ASI...ystem-944turbo
And one of these:
Should be able to get a used flange for a lot less...
One of these:
And one of these:
Tom has the links and these are the part numbers:
(3B) 930 123 134 04 Gasket
(3C) 951 123 260 01 Flange
There are two versions of the 2-piece cross over waste gate pipe extension. The one you have where the seal slides on the crossover pipe and the other the seal slide on the waste gate pipe.
Basic Sponsor
