voltage at fuel pump
I'd run a new 30A relay back there and be done with it. Heck I just did a dual relay on my new magnafuel pump on the stang. I know of some shops that gut the checkvalve on the pump to increase flow, the problem is the car starts really hard, lots of cranking, I tried it myself.
If you remove the check valve, the key just needs to stay in the "run" location for a couple of seconds, the the car will start like normal,
It's been so long since I've driven a car running the DME, I don't recall if this is possible.
I'm also running the pump off of a relay, with the pump grounded to the chassis
