Knock Knock EDIT For vid
About 1/2 a needles width under 4 bar. It builds up kinda slowly like it always has (I've posted a vid a here previously)
I've always gotten about that (4ish) on cold startups, but the needle seems slightly lower than usual. It could be my imagination...should I let the car run a little longer? - to get this reading I had it run for about 4-5 seconds -
I would always have 4 bar + a needles with above at 5,000 rpm and when cruising at 3-3.5K rpms for extendend amounts of time I would get 4.5+.
I'm going to vote for NOT a rod, as well.
Is the sound louder under the car vs. under the hood? If you can't either kill the sound or drastically diminish it by pulling plug wires, then its not a rod.
I've never heard a bad lifter be as loud as a rod knock, but I'm not an expert on these engines. I guess its possible.
I just got home from work and tried to spend solmetime with my ear and a screwdriver to isolate the knocking. Had trouble, but its possible its coming from the cam tower. While doing this, I noticed the knock goes away at higher rpms (2700-3000+rpm) ?
Short of that, pull the cam tower, cam and lifters.... MIGHT be able to rehab the lifters, but probably need a new set...
+1 on lifter noise.
I've had exactly that noise more than once over the years, both on 8V and 16V 944:s....always cleared itself after warmup/driving !
Tommy
Tommy
So I'm just leaving work now and I am trying to decide between running it long enough to warm up or tear it apart and check the lifters.....Will update later either way.
FWIW, I still suspect rod knock after hearing rod knock in other cars and listening to other videos people have posted with knocking '44s...not to say I don't hope its the lifter. Hopefully I'm wrong!
Also could be an exhaust leak, but I'd bet lifter too. A mechanics stethescope is cheap ($10 or so) and would likely confirm. You can also try pulling the cam tower plugs one at a time to help isolate the source of the noise.
Was the smoke in the cabin burned exhaust (like an exhaust leak) or burning oil smell (like you missed the fill tube)?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If it were rod knock that was that noticable on cold start up then the oil pressure would be really low - and close to zero once warmed up.
Its not just the 'normal' sticky lifter - its a fully failed lifter.
I would never bet anything on the OE oil pressure gauge readings.......... on top of that I had a car in the shop with #2 and #3 rod bearings spun and it had normal pressure all the time. Just noise and that noise went away on boost.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
True - I woulnd't bet on it...but it is usually a good diagnostic tool!
