WTB DME temp sensor, AFM
Need good used DME Eng temp sensor (not the one for the dash gauge, the other one), and good used AFM. In a hurry, car won't idle, and it's my daily. Would prefer to get both parts from the same person, if possible.
Pretty sure this is what I need, starting the car from cold, won't idle and the fans are running, so looks like the DME is getting the wrong temp info. 1986 951.
PM if you've got the parts.
Thanks!
Thanks!
you can get the dme temp sensor from Advance auto parts... most local parts stores carry them. Also I have an extra AFM if you're desperate, but I think I'd be looking at the TPS and idle control valve before trying the AFM.
Thanks for the info- didn't know advance would have that. Might have already sourced both parts. I replaced idle valve within 6 months and tps about a year ago, so I'm guessing those are OK.
