WTB Cooling fan relay
I have found the cause of my cooling fan issues.
It seems somebody had installed the incorrect cooling fan relay. Mine ends in 01 instead of 03. The 01s are an early pre-'86 version designed for a single resistor system.
Passenger side fan never worked properly for low speed but worked fine for high speed. When the passenger side fan is supposed to be running at low speed all you get is rapid clicking from the relay. I took a look inside and sure enough one of the 5 relays inside the part has been worked to death and can no longer do whatever its intended role would have been.
Now I am now looking to buy the correct relay and want to see if anybody has a spare they would be willing to sell.
