Knock counting
wouldn't the dyno charts allow for a better understanding/interpedation of what's going on? I don't mind spending a $100 to get it right the first time if that's what it takes.
Dyno won't show the knocking... if the exercise is to get rid of knock teh dyno chart won't help...all it will do is give the dyno opperator an idea of what needs to happen to your timing and / or fuel... but chances are they won't be able to change them for you, the chip companies have been doing this for a while, and can go off your current maps and a description of your needs and make the changes based on experience...
a trip to the dyno would give you a before and after chip shot though... AND Russel Berry does offer on his site to travel to you for a tuning session if needed, but he says it wont be cheap....
12 ish AFR on 93 pump gas ay WOT, Scivision MAF, Zietronix WBO2, MAP, EGT, TPS and MAF voltage monitored with a curtis knock counter that I am modifying to be able to reset and added a backlight so I can see it at night...
