my boost gauge is stuck at 1
I had a fuel line replaced just beside my fuel rail and when I got home and went back out I realized that when I turned the key the boost gauge would read 1 which is what the manual said it would do but once I cranked it it usually went back to the beginning but now it stays at 1 when the car is runing and I can bearly hear the turbo spooling and not getting the boost response. Can anyone offer some advice on this situation?
Small Business Partner
KLR is located under the passenger footwell - pull up the carpet on and it should be behind the piece of wood.
On the intake manifold, there should be a banjo bolt with two nipples on it. The hard clear'ish line is connected to one of these.
-Rogue
-Rogue
