koklen rear susp carrier
Old 07-30-2009, 10:26 PM
mikey_audiogeek
mikey_audiogeek's Avatar
Originally Posted by daigo
I never thought of that, but looking at it in the picture, you are correct on that is a design that can not avoid bending the spring plate.
Likewise with the factory (and 911, VW et al) design. The spring plate is designed to flex laterally, hence its shape. Possibly even why they called it a spring plate. Anyone designing a replacement linkage needs to take this into account - the lateral flexure stresses are significant, and the section thickness needs to be minimised. Either that or articulation at both ends.
Here's a balljoint that will fit inside a factory springplate, with a little work: http://www.pelicanparts.com/cgi-bin/...28all%29%20%20
Cheers,
Mike
Old 07-30-2009, 10:32 PM
Skip Wolfe
Skip Wolfe's Avatar
Originally Posted by TRP951
I know MPD47 had one but idk if he sold it already when he parted out his 951 stuff
I have it now. The threaded toe adjuster was siezed and snapped off so I have to have it machined out and replaced before getting it on the car.
Old 07-31-2009, 04:41 AM
gt37vgt
gt37vgt's Avatar
yeh i bet it would be hard to replicate that quality
how much do they cost any how ??
how far back is the outer pivot moved ??
why did you not return it ..
Old 07-31-2009, 06:26 AM
mikeyoman
mikeyoman's Avatar
There is still an extra piece of the aluminium casting at the end of the carrier that bolts to the body to give some extra support in that area. The original curved piece only fits into a rubber mount so isn't really supporting much just limiting twist on the torsion tube.
Also there is no provision for the handbrake cable assy with the Kokeln item.
I made up a support from 1" angle and riveted it to the underside of the carrier, did it twice before I got the correct placing !
Mike
Old 07-31-2009, 09:13 AM
hot-J
hot-J's Avatar
Maybe I'll just go with the elephant polybronze after all......
Old 07-31-2009, 10:00 AM
gt37vgt
gt37vgt's Avatar
If the kolken set up doesn't move outer pivot back ... as it looks it doesn't ... i feel they realy missed the piont .. and yeh the elephant bronze bush looks a better option
Old 07-31-2009, 11:09 PM
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Not really... you can't compare a simple bushing solution with a better bushing solution, a weight solution, a roll-center solution, and an alignment solution.
Big difference.
And by the way, the person that designed this has built the two fastest track 944's ever built. Orca and Shamoo
TonyG
Old 07-31-2009, 11:10 PM
TonyG
TonyG's Avatar
Was it installed on Chris's car when you bought it? (were you the one that bought that car from Chris?)
TonyG
Old 08-01-2009, 09:37 AM
Skip Wolfe
Skip Wolfe's Avatar
I was a step removed - I bought the car from the guy (DMoffitt) who bought the car from Chris. I bought it as a bare tub and without the Kokeln unit installed. I recently bought the Kokeln unit that was originally on the car from MPD47 who had bought it from the DMoffitt.
Old 08-01-2009, 12:06 PM
gt37vgt
gt37vgt's Avatar
So it does address the geometry issues then Nice
Quick Reply: koklen rear susp carrier
