Starting problem.
Starting problem.
So, I finally got it running. I checked everything over and let it idle for about 20mins. No leaks. No problems.
I take it for its first drive in 6yrs. I only go about a mile up the road and back. I didn't get past 3300rpms.
I pull into the garage and shut it down. I disconnected the battery for safe measure as I'm not sure if all the electrical systems are working(headlight issue).
Next day I connect the battery and turn the key. Motor turns fine. I have fuel pressure (43psi). It will not start.
Car has brand new rotor/cap/wires and plugs. Whats your guess?
