What else to do when doing the clutch?
Old 06-01-2009, 08:34 AM
ninefiftyone
ninefiftyone's Avatar
Originally Posted by KuHL 951
Sounds like you are well covered. Not sure how many miles on your car but rear wheel bearings are probably in order if your HP goals are high.
Thanks. It has about 114K so I'll just add that under the "while it is apart" catagory.
Old 06-01-2009, 09:21 AM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
Originally Posted by ninefiftyone
Well my factory rubber center is gone.
just fyi 951's never came with a rubber centered disc. good luck!
Old 06-01-2009, 02:42 PM
ninefiftyone
Really? I've had so many people tell me otherwise? I was hoping that was causing the excessive driveline slack and vibration. Anyone want to offer an opinion as to why I'm seeing so much slack?
Old 06-02-2009, 11:19 AM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
not sure why ur having that problem.
when i pulled my clutch out one of the springs in the center was sticking out sideways and being ground down.
maybe a couple of your springs just fell out? that would cause tons of slack
Old 06-02-2009, 12:13 PM
jerome951
jerome951's Avatar
I'd also suggest replacing the trans input seal. It's a $15 part and takes ~1 minute to replace w/ the trans out of the car.
May also want to consider replacing the drive flange output seals on the tranny as well. $2 seal and 1 bolt each side so very easy w/ the box out of the car.
Old 06-02-2009, 04:47 PM
ninefiftyone
Great idea. Added...
Old 06-02-2009, 04:50 PM
theedge
theedge's Avatar
Nope, no 951s with the rubber puck. 951 had spring loaded clutches, and on the original stock discs sometimes those springs would break or fall out, and cause some symptoms like a bad rubber center (driveline slack etc) or nasty grinding noises.
Quick Reply: What else to do when doing the clutch?
