cooling fan failure - Solved!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I think I have found a new failure mode for the cooling fans!
I have a customer’s car here that has a fan issue – the cooling fans run full blast any time the key is ‘on’, they turn off when the key is off. Yes, the AC is off. In fact if you pull the AC relay the fans still stay on.
Any body else run into this one?
Had the same problem a few weeks ago, turned out it was the fan switch. It had failed and was constantly running at high speeds, exactly as you described. What was weird was i started the car and was doing a walk around (cold start) and right by the drivers left wheel i heard the relays click and the highspeed fans turn on... they stayed on the rest of the trip home. Kind of funny i knew exactly when that fan switch failed..
started last week
2 weeks ago twice fans wouldn't turn off and on of which I found out when I woke up and it had killed the battery
fan switch on the list of to do's next week as usal among other fix's.....
started last week
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Remember - it turns off with the key, fans switch failure should keep the fan on with the key off - thats what different about this one!
My current problem is exactly that for the moment but a week before that it would just not turn of period but it wasn't a constant problem hence I only ever caught it twice and this week I was working on cleaning up some temporary connections I made into permanent ones and I noticed when the key was on the fans were as well but I hadn't started the car and when the key was off the fans were off.
Its confusing, but basically what i am trying to say is the high speed fans only run with the key 'on', so even with the failed switch the fans will still shut off when the key is moved to 'off' ..unless of course its the low speed fans coming on.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yes, '86 tubro
if the fans are running correctly they will continue to run on low after the key is taken out if the engine is hot. If your thermo switch fails it can keep the fans running with the key off - this is the usualy battery killer - I have seen it many times. My current problem (electrical pun!) is that the fans act like the AC is turned on - allways on high when the key is on. The strange thing is that they still run with the AC relay removed.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I did swap out the relay just to check - no change.
Not exactly, the fans will turn on with the key off on low speed at any temperature regardless. Say the car is running hot and the high speed fans are on and you shut the car off.. the fans will switch to low speed. Same as if car were running and the low speed fans were on..then shut car off, low speed fans will continue to run.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Nope, it the high temp circuit was on then the fans will run with the key off. Nice try - thanks for playing!
