Clips or no clips??? Delphi injector install question...
I have a couple different seal kits for installing injectors, but I'm guessing now I don't need them and wouldn't use them for installing Delphi injectors?
Also, I'm guessing I don't use any 'caps' as with the stock injectors?
The new Delphi's have o-rings, so just plug them in and go (aside from the resistors/new fuel map)?
I can't seem to get the clips onto the injectors & fuel rail with the Delphi injectors - the mounting slits seem to sit up a bit higher than the stock injectors. Are there replcement clips I should be using, or run w/no clips?
