Mafterburner Tuning
Hi All,
I have a Turbocharged 86 N/A with a Lindsey Mafterburner. The car runs really well but I'm trying to understand some Mafterburner theory. My car has the stock N/A DME with TPS, the TPS is connected to the Mafterburner. How does the TPS affect the Mafterburner other then selecting alternate maps? bear in mind I'm using a N/A TPS. Also I see 10.1 AF that to me fairly rich, how do these numbers look to others that have Mafterburners?
-36lb Injectors
-Adjustable FPR
-Turbo Fuel Pump
-KKK K26
Here is a snapshot of monitor session done yesterday.
-36lb Injectors
-Adjustable FPR
-Turbo Fuel Pump
-KKK K26
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Ok it looks like from the 2.6V to about 3 V you are way rich. 3V to 3.9V your ok. Last but not least 4V on you are lean. Do I understand this correctly that this is a previously an N/A car that has been turboed with no KLR??
Yes, this is turboed N/A with no KLR but I use a J&S Safeguard to control knock.
Thanks !!
Here is another sample.
