Head Gasket thickness question?!
I picked up a 951 for a later project. Right now the car has 1 bent exhaust valve keeping it from running.
I would like to throw the engine toghether and use the car until I determine exactly what I want to do with it. (V8, build a 3.0L, etc).
The car has a bunch of performance mods on it and I have paperwork showing that this head has been ported, polished and 0-ringed.
Checked the other valves, they all seat good, cleaned the head up. . I think I can "get a way with" just replacing the valve at the moment. (not my long term solution).
I understand the stock head gasket is 1.1mm thick. Where is that measured at?
I stuck my calipers on this head gasket and it is 1.6mm thick(ish) at the thickest spot. Want to make sure I am ordering the right thickness to put back in this car.
How deep is the reference hole supposed to be? (so I can see what was shaved off this head in the past).
I searched and did not quite get all the answers I need.
Stock or Widefire are .040". If you want thicker, you got to go cometic.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Great thanks guys.
FWIW I have seen 4-5 places to get the stuff. Been on the Lindsey site a few times looking at everything from heads to other fun stuff. Since they were helpful here, I think I should order from them. Will be buying shortly.
Thanks.
Now, how the hell do I tell if my waterpump is updated etc for ordering this timing belt kit to go with it?
Thanks.
