FS: Lindsey MAF, power pefect, narrowband, & 55# injectors
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
So you decided not to use the set up then ?
That maf is a stage 2 and it is dated feb of 08 for the build of it but you also need to know what it was set up for the "flow" it could be a 25-30 or even greater you need to contact lindsey to know for sure by vin.
But if it was on a stock turbo car it was more then likely a 25.
Yeah I decided to change set-ups. I have no knowledge about this set up or how it works so I am going to cut my losses and start over with a product that has great customer support. I figured this MAF will be great for someone who knows this particular product better than I do. This MAF was on a car with a Lindsey sport turbo so it should be fine for cars with bigger turbos.
MAF and Power perfect now on ebay, very low reserve on both so bid away, thanks.
MAF Kit
Power perfect
MAF Kit
Power perfect
