Replace axle instead of doing CV joints
I've got a whooshing / clunking sound in the rear that I can hear at low speeds. it gets slower the slower I am rolling along. At high speeds I can't really hear it because of the exhaust and wind noise, but I think it is there then too. CV joints right?
So I am thinking of just replacing the half axles since they come with the CV joints ready to bolt on and the price difference is like $10 per side. Is this what everyone else does?
Rotating really works.
I've rebuilt axles before and it's a very messy job. If you must replace them, then it's definitely worth considering buying them ready to install.
That said, not all CV joints are the same. GKN makes different qualities and those from Porsche are a higher grade. Make sure you know what quality you're getting. Especially for a 951.
And use new bolts. They are designed for a single stretch, and repeated torquing puts them beyond their tolerance level. Yes, people (myself included) have reused them without problem and in a pinch, I would still do so, but its pretty cheap insurance to put the new bolts in ala FSM spec.
Mine were making a clicking sound under acceleration. I took them apart and cleaned them, not much wear so I just slapped some new boots on with fresh CV grease and flipped them 180 degrees and they have been perfectly quiet since. It is a big mess cleaning them though, get a gallon of fast orange! Overall a pretty easy job though and could save you a few hundred bucks if the grease just old.
I've had the entire right side back out to failure. Admitting that I've not checked the TQ specs, but if I could simply see a broken white line, I would have been notified of what was happening. I now have an easy guide with a bottle of white out.
G
It's what I've done. Many like to just get dirty. Always replace with new bolts. Mark the bolts with white out after TQing to spec. They may back out, and it's easier to inspect. Seeing a white line brokes, is easier than putting a TQ wrench on all those little allen bolts.
G
G
Just make sure to use the stock triple square or "cheesehead" bolts, because they're a lot less likely to round out than allen bolts!
Cheers, Mike
Also, what is a good torgue wrench range to go with? I'm looking at a 25-250 1/2 wrench on Amazon.
http://www.amazon.com/Mountain-16250...ef=pd_sim_hi_2
As for a torque wrench, as long as it's a decent quality brand you should be fine.
