Clutch fork is hitting the Bellhousing before the Pedal hits the floor
I have a spec flywheel, KepI, 6 puck clutch. The Clutch fork is hitting the bellhousing before the pedal hits the floor. I measured i have 9.30 mm between the fork and the Bellhousing. Stock is 18mm
Jane Bond 007
That's not good. I had the same issue and it ended up being the clip holding the throwout bearing. It had stretched out and fallen off and the fork was just loose. Had to tear everything down to replace a stupid clip
While I was doing my research, I discovered quite a few broken forks as well so I installed a new one.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Yes you probably have a bent clutch fork or a ear has broke off of it sorry to here.
