SFR MAF WIRING '87 951
PREVIOUS OWNER INSTALLED SFR STAGE TWO MAF WITH ARC2 CONTROLLER BUT DID A HACK JOB ON THE WIRING, BRINGING THE MAF HARNESS INTO THE FOOTWELL AT THE ECU (NOT SURE IF THE SFR WAS TO BE WIRED THIS WAY OR NOT)--BUT I AM SWAPPING OUT THE ARC2 AND PUTTING IN THE VITESSE PIGGYBACK AND NEED HELP IN CONFIRMING THE PINS AT THE ECU THAT THE MAF WIRES ARE TO GO TO--ANY ONE HELP?
MAF is DME #7. It should pass through the ARC2.
MAF ===> Wire #7 DME cut ===> ARC2 ===> Wire #7 DME.
Verify with Tim for correctness.
