Guys with Mafterburner - TPS at WOT
Those with the mafterburner.... what do you see for a TPS angle at WOT ?
I am seeing 71 degrees. Just wondering if I need to adjust a throttle cable or not.
Basic Sponsor
No. What you need to do is go WOT with the key on and engine off. See what the max voltage reading is you get. Enter that voltage into the MB settings. Then when it see's it, it will say 100%. Right now your reading 71% of 5 volts, but your max voltage is around 3.5.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
I looked around and added that voltage to the right place but didn't see anyway of updating it, so it still reads 75% at WOT.
Where exactly do you make and update these changes in the mafterburner software?
When I have the throttle to the floor and the engine off it reads 2.990 so i put that in to the mafterburner in the TPS WOT Breakpoint, and it still reads 64 degrees throttle.... I tried with other values and no matter what I put in that box it always reads 63-64degrees of throttle.
Matt
Matt
