Would the 996 radio fit the 944?
I don't know about that one, but a whole lot of aftermarket radios will fit. If the original harness has not been cut, then you can get connectors to make the install much easier.
Going with the pack
is quite monotonous.
I think there was talk about the boxster's radio display being hard to read due to the viewing angle being different...
What is the make/model of the HU from the 996? That would be considerably more helpful in figuring out if it will work or not.
I know there it's a problem even if you fit the face plate the cdr will start in protected mode. I also have the bose amp that comes optional but it seems that only recives optical imput signal. CDR 220 starts on CAN BUS and I think it might need to be cracked to work on other cars.
The Becker CDR220 only has a security code - there's no CAN bus connection at all. Are you talking about a CDR23 (BE6612)?
