Re-installing stone guards
Does anyone have any advice on how to re-install the stone guards? I've gotten the old ones off, but now I want to make sure I position the new ones properly. I searched and didn't find anything.
Chuck
Chuck
Get a pan big enough to hold the guard, and fill it with a a mixture of water and rubbing alcohol. Dip the stone guard and get it entire wet, then when you position it on the body it will slide around as you position it. Use a plastic squeegie to press it on and slide the air bubbles out, working from the center out. Make sure the paint is clean as a whistle before applying the gaurd. Don't try to do it dry -- you'll get finger prints in the adhesive and it'll be almost impossible to place properly on the first try. The adhesive is unaffected by the water/alcohol, so no worries there.
Also a spray bottle can be used in place of the pan, just make sure you get the side of the car good and wet, as well as the adhesive side of the dacals... Take your time and everything should be fine...
