Oild cooler fitting size
Anyone know the AN fitting size on the KISS oil cooler (13 row mocal unit)
then is the unit a 115 or 235 matrix. I need to order a new one and looking at http://64.202.180.37/files/cool$.pdf but need sizes
These are some of the fittings I used. I ordered the Kiss system and then decided not to use it (sent it back). I used two stock coolers instead. You can find these at True choice motorsporsts in Ohio (same day ship and my recomendation). Or you can find them at Pegasus Auto Racing in Wisconsin. Probably avialable locally as well.
3265-38 22 x 1.5mm to 12AN Male Adapter for Setrab Oil Coolers, Alum
http://www.pegasusautoracing.com/pro...asp?RecID=4213
3270-12-FOOT #12 Size Stainless Steel Braided Racing Hose
http://www.pegasusautoracing.com/pro...p?Product=3270
3271-12-045 45' Aluminum #12 Hose End / 12AN
http://www.pegasusautoracing.com/pro...p?Product=3271
3271-12-090 90' Aluminum #12 Hose End / 12AN
Thnaks guys, I actually already have the kiss system installed but need to replace the cooler unit as it is damaged.
So I need to order my replacement cooler with 12AN male fittings.
Anyone else confirm if the KISS unit is 115 or 235 martix?
